Solar-Putty window size on opening
Hi - is there anyway of changing the default window size when opening a session in SolarPutty? I have played around with the putty.exe settings (columns/rows) and the window size is affected for Putty directly but then when opening SolarPutty the window is always extending past the taskbar at the bottom and at the top of the screen, seemingly ignoring any settings from the Putty session. To resize the screen I have to pull in the sides of the display and then I can resize it. Prob a simple setting somewhere in SolarPutty to retain the settings on open or exit?  Thanks
Parents Reply Children
