Solar-Putty URL Integration Problem
I am facing a problem with Solar-Putty integrating with URL handler,
like when I open a hyperlink (telnet://192.168.1.22:53694) with normal putty or SecureCRT
a new tab is opened with the requested session
here is a reg file that I use to integrate putty into windows registry
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Classes\Solar-PuTTY.telnet]
@="telnet"
[HKEY_CURRENT_USER\SOFTWARE\Classes\Solar-PuTTY.telnet\DefaultIcon]
@="C:\\Program Files\\EVE-NG\\Solar-PuTTY.exe,0"
[HKEY_CURRENT_USER\SOFTWARE\Classes\Solar-PuTTY.telnet\shell]
[HKEY_CURRENT_USER\SOFTWARE\Classes\Solar-PuTTY.telnet\shell\open]
[HKEY_CURRENT_USER\SOFTWARE\Classes\Solar-PuTTY.telnet\shell\open\command]
@="\"C:\\Program Files\\EVE-NG\\Solar-PuTTY.exe -t -h "  %1"
[HKEY_CURRENT_USER\SOFTWARE\Solar-PuTTY]
[HKEY_CURRENT_USER\SOFTWARE\Solar-PuTTY\Capabilities]
[HKEY_CURRENT_USER\SOFTWARE\Solar-PuTTY\Capabilities\URLAssociations]
"telnet"="Solar-PuTTY.telnet"
[HKEY_CURRENT_USER\SOFTWARE\RegisteredApplications]
"Solar-PuTTY"="Software\\Solar-PuTTY\\Capabilities"
[HKEY_CURRENT_USER\SOFTWARE\Classes\telnet\shell]
[HKEY_CURRENT_USER\SOFTWARE\Classes\telnet\shell\open]
[HKEY_CURRENT_USER\SOFTWARE\Classes\telnet\shell\open\command]
after multiple tries I could open a session with Solar-Putty But with wrong telnet number which is always the default telnet port number
please fine the attached image for more details about the Problem.
Parents Reply Children
No Data
