do you know where can be the problem when I run Analyze of a domain user and folder the error is occured:
7/18/2012 10:53:11 [17] DEBUG FileRights Getting effective entries
07/18/2012 10:53:11 [17] DEBUG FileRights effective entry: KOMPAN-DK\UK Project: : AppendData, CreateDirectories, CreateFiles, Delete, ExecuteFile, ListDirectory, Modify, Read, ReadAndExecute, ReadAttributes, ReadData, ReadExtendedAttributes, ReadPermissions, Synchronize, Traverse, Write, WriteAttributes, WriteData, WriteExtendedAttributes
07/18/2012 10:53:11 [17] DEBUG FileRights Merging
07/18/2012 10:53:11 [17] DEBUG FileRights Returning ShareSecurityItem <empty>: AppendData, CreateDirectories, CreateFiles, Delete, ExecuteFile, ListDirectory, Modify, Read, ReadAndExecute, ReadAttributes, ReadData, ReadExtendedAttributes, ReadPermissions, Synchronize, Traverse, Write, WriteAttributes, WriteData, WriteExtendedAttributes
07/18/2012 10:53:11 [01] INFO Progress
07/18/2012 10:53:11 [01] INFO Progress Reading Share rights
07/18/2012 10:53:11 [17] DEBUG MainWindow Impersonating for GetShareRights Domain='DOMAIN' and username='user'.
07/18/2012 10:53:11 [17] DEBUG ShareRights Creating instance for path '\\name_of_the_server\Company Projects\'
07/18/2012 10:53:11 [17] DEBUG ShareRights Opening remote registry on machine name_of_the_server
07/18/2012 10:53:12 [17] DEBUG ShareRights Getting security descriptor
07/18/2012 10:53:25 [17] ERROR ShareRights Exception: System.IO.DirectoryNotFoundException: Attempted to access a path that is not on the disk.
at EpReader.FileRights.ShareRights.GetShareRights(Logging log, String fullShareName, IActiveDirectoryHelper adHelper)
07/18/2012 10:53:25 [17] ERROR MainWindow System.IO.DirectoryNotFoundException: Attempted to access a path that is not on the disk.
at EpReader.MainWindow.<>c__DisplayClass10.<PerformAnalysis>b__9()
07/18/2012 10:53:25 [01] INFO Progress Failed to read Share permissions. Directory does not exist.
07/18/2012 10:53:25 [01] INFO Progress Merging results
07/18/2012 10:53:25 [01] INFO Progress Finished.
07/18/2012 10:53:25 [17] DEBUG MainWindow Membership cache deleted.
The output of NTFS rights I can see properly...
Remote Registry Service on a target machine is running automaticaly.
Thank you for help.
