This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Permissions Analyzer not displaying NTFS permissions
When I try to analyze permissions on a file or folder, share permissions are enumerated correctly but not NTFS. The analyzer log file shows that it can find the AccessRightsDatabse object but the credentials for the domain are not available.  There are two domain controllers and the analyzer displays the same results regardless of which controller is used.  Does anyone have ideas of where I need to start looking to correct this issue?
