Monitor does not display.
 I have installed the Exchange Monitor on a windows 2003 server with exchange installed on it etc....Everything goes fine during the install but once it's installed the icon appears in the system tray and a button appears in the task bar as if a window should be showing me something. It does the same thing if I click on the edit configurations as well. I have no type of dashboard or configuration display at all. Program is there, says it's running. Appears to run...just can't see anything. I must be missing something...I have no clue what tho. I installed it locally on my xp system and it seems to work just ducky.....
any thoughts here would be appreciated.
