HELP! WSUS clients not reporting - log attached
I can't get my clients to report.  Ran the diag...here's the output.  Any ideas?
# SolarwindsRegistered Diagnostic Tool for the WSUS Agent
# 7/25/2013
Machine state
  User rights:                                       User has administrator rights
  Update service status:                             Running
  Background Intelligent Transfer service status:    Running
  OS Version:                                        Windows Server 2012 Standard
  Windows update agent version:                      7.8.9200.16604 (WU Agent is OK)
Windows Update Agent configuration settings
  Automatic Update:                                  Disabled
  Options:                                           Not found (There is no such key)
  Use WSUS Server:                                   Enabled
  Windows Update Server:                             http://wsus:8530
  Windows Update Status Server:                      http://wsus:8530
  WSUS URLs are identical:                           Identical
  WSUS URL is valid:                                 Valid URL
WSUS Server Connectivity
  clientwebservice/client.asmx:                      OK
  simpleauthwebservice/simpleauth.asmx:              OK
  content:                                           Error: Forbidden (Incorrect proxy client configuration - use settings tab to test proxy configuration settings; may also be caused by misconfigured SSL implementation or access rights on WSUS server)
  selfupdate/iuident.cab:                            OK
  iuident.cab:                                       Error: NotFound (Omitting required port suffix on URL to access WSUS installed to port 8530 or resource is unreachable)
Parents
  • Greetings.
    The "error" on the content target is known to be caused when the Directory Browsing module is installed. As it turns out (I only actually realized this other day), the Web Role installer selects Directory Browsing by default (in Common HTTP Components), and arguably that's a defect. Directory Browsing should not normally be installed on a web server unless a specific application requires that functionality. Uninstalling the Directory Browsing module from the Web Server role will eliminate this "error".
    The "error" on the iuident.cab target is a manifestation of WSUS installed on Windows Server 2012. The Diagnostic Tool checks for this target in the root of the WSUS website, and WSUS v6 (on WS2012) no longer copies that file to that location.
    However, what is impacting the functioning of your client appears to be that the Configure Automatic Updates policy setting has been DISABLED somewhere along the way, or a script is being applied that sets the NoAutoUpdate registry value to TRUE. The second line "Options" refers to the fact that the diagnostic tool could not find the presence of an AUOptions registry value. While AUOptions is not strictly required (it will default to '4' using internal WUAgent settings), the first line "Automatic Update: Disabled" is the critical condition.
Reply
  • Greetings.
Children
No Data
