quote:Originally posted by dclecompteIs your database on the same box as the Orion we server? We recommend separate boxes.
quote:Originally posted by dclecompteCould you elaborate on the database locking problem? That may or may not be relevant to the problems you are seeing. We need more detail.
quote:Originally posted by dclecompteHave you contacted Support directly yet? You probably need more real-time troubleshooting than the forum can provide.
Unfortunately I have the same problem
Do you have solution for this problem? Please be so kind to share it with me...
Really thanks for your help in advance ,
eDiT
Hello edit.csato-
What exactly is the performance issue you are having? and what versions are you using? I ask because this thread is somewhat dated and new releases may have addressed the issues you are having.
Hi All,
FYI. My problem has solved by inceasing our tablespace.
regards,
